Reply
Re: List of missing devices from Compatibility Checker
@pr4mr wrote:
Wasted time and money on sim card and plan, and my phone says invalid sim card!
phone is    LG L44VL
Sorry, but a phone with only CDMA and LTE won't be any good here. While LTE might work (depending on frequencies supported) for data an text messaging, you won't be able to make or receive any phone calls with this device.  That device isn't really any good for any carrier here, so I highly suggest purchasing a different phone.
Em03
Looking to see if there is compatibility to the Samsung A6?
pazmariano
Hi,
Please include Samsung Galaxy J& Pro in the list so I can use my mobile data soonest because I needed it at work.
Thank you.
Maria Paz Mariano
geopublic
@pazmariano wrote:
Hi,
Thank you.
Maria Paz Mariano
@pazmariano  If the J3 Pro is the North or South American model it will work without any issues.
pazmariano
Hi,
It's Samsung Galaxy J7 Pro. Is it compatible with the Sim?
Thanks.
geopublic
@pazmariano wrote:
Hi,
Thanks.
@pazmariano  Yes, that phone supports all  the necessary bands and will work without any issues. PM sim card are tripunch so no issues there either.
brettster99
@pazmariano
Does it have this somewhere in the about section
SM-J710F*
 850MHz, 1900MHz
Band5-850MHz, Band7-2600MHz
SM-J710M*
850MHz, 1900MHz
 Band17-700MHz, Band5-850MHz, Band4-AWS, Band2-1900MHz, Band7-2600MHz
Because if it does then it is supported by Public mobile
gblackma
It's 100% compatible has both the required 3g and 4g bands @pazmariano . Stay safe.  The PM SIM is a tri punch one fits all 3 of the sizes.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Note- your old providers account must be active to port.
pazmariano
Hi,
Thanks for your reply. But I cannot enter APN details because it prompted settings are not available for the user. Hope anyone can help with this.
Thank you.
brettster99
@pazmariano @gblackma
Samsung galaxy j7 pro. Need help with APN settings
