Reply
Highlighted
Re: List of missing devices from Compatibility Checker
@deannev wrote:
I will follow-up with Apple again, but I have yet to see a confirmation from someone who is actually using the iPhone SE 2020 with public mobile's network.
Thanks.
I typed in "iphone se 2020" (no quotes) in the search above and found lots of results.
The phone will work.
Can you call the previous provider it was on?
Can you connect via usb and run itunes and see if something will update? All this Apple stuff is murky for me though 🙂
Highlighted
Hello
You are missing Samsung Galaxy A51 from your lkist
Highlighted
I have an iphone SE 2020 A2275 and it works fine.  You will need to go to "unlockit.co.nz" to set up APN though.
Highlighted
LG-M151 is missing on compatibility list
Highlighted
Please add the Blackwell BV9100 to the list to check. Thank you
Highlighted
Highlighted
Highlighted
Samsung Galaxy A51 is compatible
Highlighted
Xiaomi Redmi Note 9S is missing from the list.
Tags (1)
