Thank you! Still trying to figure out how this all works - referral code?
@spud18 yes a referral code meaning a friend or family member referred you to Public Mobile. When you activate a sim card while signing up there is a spot to enter the code. You'll get $10 credit to your account for it that can be used on 2nd payment for your plan.
It sounds like you don't have one so if you look at top right of your page the envelope. That is your private message inbox. I sent you one if you want to use.
If you have any further questions we are here to help.
Once you have a sim card go to link below to activate.
@spud18 Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Please add Motorola G8 Power Lite
I can't find "REDMI NOTE 7 Pro" in the list. Is this compatible?
@prach004 wrote:I can't find "REDMI NOTE 7 Pro" in the list. Is this compatible?
A device doesn't need to be on the list to be compatible. At the very least, customers should be looking for devices with at least UMTS band 2 and 5 capabilities. The information that I've found says that there is a version that has that, but that doesn't mean that there can't be multiple versions of this model.
@prach004 yes as long as it's the global version.
I have a Easyfone prime A1, model C512W , it is not on your list
The pm list isn't always up to date. Check your phone at the link above.
Motorola Moto G Power and Motorola Moto G7 Power
