Reply
Triguy
Re: List of missing devices from Compatibility Checker
Lucas678
Xiaomi Redmi Note 9s
Looking at getting this phone but it's not on the compatibility list. Please respond if you use one on this network
Naepalm
@Lucas678
You can check this Telus IME# Check and it will tell you if it works on the network.
http://mobility.telus.com/devicecompatibilitycheck/?locale=en
Shows that it is compatible although it does not have use of all bandwidths.
( edit: picture removed) @computergeek541
Have a great day!
@Naepalm wrote:
@Naepalm Whichever website that screenshot came from, I highly suggest not using it.  It will only confuse people.  The information provided is incorrect. Public Mobile does not have any 2g-type network.  This could potentially cause people to think that a phone is compatible when it isn't.
Triguy
It is compatible based on these specs.
https://m.gsmarena.com/xiaomi_redmi_note_9s-10147.php
Make sure it is unlocked.
David_J
Public Mobile
@computergeek541 is correct - Telus/Public Mobile doesn't have any 2G network available in 2020. I would recommend either using the phone compatibility check on https://www.publicmobile.ca/en/on/get-started or the https://willmyphonework.net/ website.
gblackma
@Naepalm isn't that checker from the Telus website? Thanks. Stay safe.
@gblackma
I'm thinking that could be frequencycheck.com.  They've been made aware that the information that they are presenting is wrong but don't seem to care.
Naepalm
 Site was KImovil
Weird they would show 2G if there isnt a 2G network lol
z10user4
@Naepalm wrote:
 Site was KImovil
Ya mean not everything on the internet is true? I don't think that's true 🙂
