List of missing devices from Compatibility Checker
Alan_K
Hi Community,
Thank you for the positive comments on the new phone compatibility checker. As you may know, we partnered with willmyphonework.net and utilize its extensive catalog of mobile devices. With that said, you’ve highlighted to us that there are devices that are not captured still, and we want to keep track of that here to provide feedback on a regular basis.
Please comment below your phone make and model that wasn’t found on our checker and we’ll be sharing on a monthly basis back to our partners.
Thanks,
Public Mobile Community Team
List of missing devices added (July 2019)
Click below to open the list of devices:
Spoiler
  • BlackBerry KeyOne
  • BlackBerry Key2
  • BlackBerry Motion
  • OnePlus 7
  • Pixel 3a
  • Moto G7 Play
  • Moto G Dual SIM
  • LG V20
  • LG V30
  • LG V40
  • Samsung Galaxy S10
  • Samsung Galaxy S10e
  • Samsung Galaxy A5
  • Samsung Galaxy A7
  • Samsung Galaxy A10
  • Xiaomi Redmi Note 7
List of missing devices added (August 2019)
Spoiler
  • BLU Studio C6L
  • Maxwest nitro 4x
  • Motorola G7 Play
  • Nokia 5
  • ASUS Zenfone 5z
  • Palm Phone PVG100
  • STK Device Family (Coming soon)
153 REPLIES 153
BenG
iPhone SE 2020  Model 2275 is compatible.  Just had to remember to break the SIM card down to the smallest size.  Only took a couple of minutes to come up.  Everything works and even have service better than I had with the Moto G4.
@BenG wrote:
Will iPhone SE model A2275 be added any time soon?  Just ordered it from Costco...
Remember that a phone model doesn't necessarily need to be in the list the work. The compatibility checker is for reference only.
BenG
slugbug55
Add ZTE Fanfare 3 Z852 to the compatible list.
PabloDuke
Xiaomi Redmi Note 8T
texxaport
Xiaomi Redmi Note 9S is missing from the list.
spud18
Samsung Galaxy A51 is compatible
PatNiC
Please add the Blackwell BV9100 to the list to check. Thank you
Gramma10
LG-M151 is missing on compatibility list
rolomi
I have an iphone SE 2020 A2275 and it works fine.  You will need to go to "unlockit.co.nz" to set up APN though.
Scarry
Hello
You are missing Samsung Galaxy A51 from your lkist
@deannev wrote:
I will follow-up with Apple again, but I have yet to see a confirmation from someone who is actually using the iPhone SE 2020 with public mobile's network.
Thanks.
I typed in "iphone se 2020" (no quotes) in the search above and found lots of results.
The phone will work.
Can you call the previous provider it was on?
Can you connect via usb and run itunes and see if something will update? All this Apple stuff is murky for me though 🙂
deannev
Thanks.
 @deannev
The compatibility list is poorly maintained. That version will work perfectly fine here.
iphone folks will be better than me for the error.
All phones from outside the Telus family have to be unlocked before being able to use them here.
deannev
I believe the IPhone SE (2020) model A2275 is not compatible at this time ('No SIM' error when SIM inserted) and it doesn't show on any of the lists. Will the iPhone SE (2020) be added soon to compatible PM phones?
Richmurray
Much appreciated:)
@Richmurray wrote:
Thanks a bunch...  what referral code?
It's a code for existing customers to refer to new customers. The new customer gets a $10 credit. The existing customer gets a $1 reward each term.
You've probably already been deluged with a bunch.
@Richmurray  a referral code is a code given by a friend that's with public mobile or family member or you can ask here and someone will send you one via private message to use when you sign up for a $10 bonus
Be sure to ask though as many probably sent you one already which is not allowed. But if you ask someone for a code then they can send it to you and you can use it.
Richmurray
@Richmurray
Yes it will work. See link below where someone else asked.
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Is-samsung-a71-compatible-with-pub...
Don't forget to use a referral code for a $10 signup bonus.
Richmurray
Does the samsung galaxy A71 WORK with public mobile?? It's the unlocked version
curlybennett
Please add Huawei P Smart 2019
laurestine
Motorola Moto G Power and Motorola Moto G7 Power
https://willmyphonework.net/
@casimir
The pm list isn't always up to date. Check your phone at the link above.
casimir
I have a Easyfone prime A1,  model C512W , it is not on your list
@prach004  yes as long as it's the global version.
@prach004 wrote:
I can't find "REDMI NOTE 7 Pro" in the list. Is this compatible?
A device doesn't need to be on the list to be compatible. At the very least, customers should be looking for devices with at least UMTS band 2 and 5 capabilities.  The information that I've found says that there is a version that has that, but that doesn't mean that there can't be multiple versions of this model.
prach004
