LG G8X ThinQ
LockeS
I just purchased an LG G8X ThinQ phone and have used my public mobile SIM card in it.  The PublicMobile webpage does not include this phone in their list of phones that will work, but it does.
LockeS
I was looking at Costco.ca but went with an open-box from BestBuy as it came with the second screen for almost the same price.  So far the phone is great.  A little heavy with the case on it, but the dual screen is nice.
LovesToPM
Hi @LockeS
You've proved that the phone works!
The PM site lists 2 close variations of the phone: G8 ThinQ & G8s ThinQ
It's a pretty good phone and well priced if you got it from Costco.
$500 in-store or $520 online:
https://www.costco.ca/lg-g8x-thinq-128-gb-aurora-black-unlocked-smartphone.product.100657778.html
Staliger
@LockeS Yes, that's right. It is okay. PM's database is not fully updated with the phones supported by this provider. My phones are not in the list, but they are working great.
Hi @LockeS , the list of phones is not up to date like it could be, there should be no problem with this phone.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS)
LG G8X ThinQ NETWORK:
TechnologyGSM / CDMA / HSPA / EVDO / LTE
2G bandsGSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 (dual-SIM model only)
 CDMA 800 / 1900
3G bandsHSDPA 850 / 900 / 1900 / 2100
 HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 - USA
 CDMA2000 1xEV-DO
4G bands1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 20, 28, 32, 38, 39, 40, 41
 1, 2, 3, 4, 5, 7, 12, 14, 20, 29, 30, 38, 39, 40, 41, 46, 66 - USA
SpeedHSPA 42.2/5.76 Mbps, LTE-A Cat20 1960/75 Mbps
popping
An unlocked LG G8X ThinQ from any Canadian providers should work with PM.
Koodo is selling LG G8X ThinQ.
https://www.koodomobile.com/phones/lg-g8x-thinq
