Just registered with Public Mobile, my phone is asking me to "enter network unlock code"
JMO
I tried 1234 which someone said to try and it didn't work. What should do from here, do I need to talk to a moderator?
7 REPLIES 7
JMO
Thanks everyone, will call Virgin now
cavemantoronto
It is a locked phone. The message means that and that's for sure. Moderators can't do anything. Get code from old provider. Who said try 1234? That's a terrible idea. Don't guess unless you want to permanently lock phone. Code to unlock from a  network isn't guessable.
Hi @JMO
Virgin mobile is obligated to provide you with the unlock pin after 90 days of service.
Phone manufacture as well
Give them a call or even better go for the live chat seems to be faster
Lar
Seems Virgin do lock phones to their system so it will need to be unlocked. Have a look at this site  https://www.virginmobile.ca/en/support/faq.html?q=unlocking-your-phone&province=ON&geoResult=failed
@JMO
Contact Virgin Mobile customer service and ask them.  Likely locked phone.  VM will offer the code for free.
JMO
I was with Virgin Mobile, is there anyway to know if it was unlocked or not?
Lar
@JMO  Is your phone unlocked from your last provider?  If not then you will need to contact them to get it uhlocked.  Cheers
