Reply
LT3
Re: Is the Samsung Galaxy A32 5G compatible with the Public mobile SIM card?
My current SIM card is a Micro SD for my Samsung Galaxy S4, would that fit in the Galaxy A32 5G phone for public mobile? thanks.
darlicious
@LT3
Your A32 probably takes a nano that you could snap out of the micro frame. Then just keep the micro frame just in case.
no, as mentioned above, you will need a nano SIM..
HOWEVER,  take your SIM card out to see if there is a "frame" outside of your micro SIM.  If so, you can remove the frame to make it nano SIM and use it on A32
