Is my Samsung A50 compatible? (SM-A505G)
NateFrom613
Hello, I recently bought a Samsung A50 (Model: SM-A505G) from amazon and was wondering if it is compatible with the Public Mobile network  and whether or not they make compatible SIM cards for my phone. I wasn't able to find the phone on the compatability list.
If it helps, this is the link I bought my phone from. It has all the phone's specs: https://www.amazon.ca/Samsung-A50-Display-Unlocked-International/dp/B07QQYHSR5?th=1&psc=1
Jonnyreloaded
I just activated my Samsung a50 from Amazon as well and it works great.
ben89
Yes it is 😉 I have the same phone
@NateFrom613
Your phone will work with Public mobile and the standard PM Sim card will fit in your phone.
Your phone specs:
https://www.gsmarena.com/samsung_galaxy_a50-9554.php
3G bandsHSDPA 850 / 900 / 1900 / 2100
 HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 - Canada
4G bandsLTE band 1(2100), 3(1800), 5(850), 7(2600), 8(900), 20(800), 38(2600), 40(2300), 41(2500)
 LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 12(700), 13(700), 17(700), 20(800), 26(850), 29(700), 38(2600), 40(2300), 41(2500), 66(1700/2100), 71(600) - Canada
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
station1104
It sure is as long as it is unlocked!
geopublic
@NateFrom613  Yes, it will work with Public Mobile without any issues.
