Is compatible with Public mobile Xiaomi Redmi Note 8T?
PabloDuke
Hi community,
I cannot find my model on the list of compatible cell phones but seems weird to me. Can anybody let me know if you are using this cell phone with Public mobile?
Many thanks.
Pablo
10 REPLIES 10
PabloDuke
Yep, data is working well also and I haven't needed to re-set up any APN setting... No problems for the moment, just a little issue when the Xiaomi tried to activate the number in my account, but it seems solved... I'll post whatever happens but for now it's totally functional.
Thank you!
Jb456
@PabloDuke  Is your data working also? Sometimes these type of phones have greyed out APN settings that can't be changed. The work around is a freedom mobile sim to edit the apn settings or asking a moderator if they can possibly send an APN config file to the phone.
If everything is working than that is great and if you used a referral code for a $10 sign-up bonus that will be credited within 72 hours.
Welcome to Public Mobile 🙂
PabloDuke
Thank you to everybody for all your help!!
I just activated the Public mobile´s sim card and it seems working without trouble in my device.
Best!
balaca
I use Redmi 5A bought in India (from Amazon India) with Public Mobile.
Phone latches onto the network just fine, regardless of whether I set 'LTE' or '3G' to be Preferred Network Type.
Jeremie10
Try resetting your mobile data first, restart your phone and then try again. This should work 📱
Pound
I have a Redmi, too. Not the same model as yours. Mine works well with Public Mobile.
will13am
@PabloDuke , Xiaomi phones will work.  Make sure you get the global model.
Jb456
Helpershelper
Triguy
It should be compatible but make sure it is unlocked.
https://m.gsmarena.com/xiaomi_redmi_note_8t-9946.php
