I am wondering if public mobile will work with my Nexus 6P phone. I want to make the switch to Public Mobile but Nexus isn't even listed in the Phone Capatability tool.
did you try www.willmyphonework.net
@jwhite18 check it on willmyphonework.net
If it was with bell/ Telus it should work!
It should be compatible with PM based on the specs.
@jwhite18 wrote:I am wondering if public mobile will work with my Nexus 6P phone. I want to make the switch to Public Mobile but Nexus isn't even listed in the Phone Capatability tool.
Yes, it works
It's compatible, I've used one.
Yes Nexus 6P works fine with PM.
Yes, absolutely.
Here is the link to the Check your phone's compatibility tool from the website :
https://www.publicmobile.ca/en/on/get-started
Just scroll down and click Start Checking 🙂
Regards,
Public Mobile Moderator team
