Reply
Highlighted
Is Xiaomi Redmi Note 9S compatible with the network?
See title please! Phone bought in Japan. Is 4+64GB model.
Highlighted
Re: Is Xiaomi Redmi Note 9S compatible with the network?
@texxaport hi, yes this phone has the correct bands/frequencies to work with public mobile.
Highlighted
@texxaport , did you get the global model or the one for the local market?  If you didn't get the global model, you will have mostly 3G connectivity.  I think on LTE, you will only have band 5 compatibility.
Highlighted
@texxaport I have a Chinese version of Note 8. It works perfectly with PM. I think your 9S will not have any issues as well.
Highlighted
This is is off their specs page for Global Version. Not sure what the difference is for any local market ones though.
Model
 Xiaomi Redmi Note 9S Global Version (6GB+128GB)
Network
 2G: GSM B2/B3/B5/B8
 3G: WCDMA B1/B2/B4/B5/B8
 4G: FDD-LTE B1/B2/B3/B4/B5/B7/B8/B20
       TDD-LTE B38/B40
 SIM Card Slots: Dual SIM Card Dual Standby (Nano-SIM), Supports 2+1 card slot, nano-SIM + nano-SIM + TF
