Is LG Q6 Compatible with Public Mobile ?
@rmk1980 wrote:Is LG Q6 Compatible with Public Mobile ?
Yes, just make sure you reset your network settings after inserting the PM sim card to get data working. If data is still not working then you will need to do a factory reset to get it to work.
I have the Q6 and I am now with PM. No worry. Some phones don't work with Freedom Mobile and their network isn't as good.
