Iphone Carrier Unlock
notorious
Hi PB MOD I need to get my Iphone Unlocked it is locked to a carrier and in order to use it I have to unlock it.
popping
You need to contact the carrier who sold you the iPhone to get it unlocked.
Since 1 Dec 2017, all phone sold in Canada must be unlocked.  If you don't know which carrier sold your iPhone., you can contact Apple Store to get it unlocked as long as it was sold in Canada.
@MacMe wrote:
@krazykiwi wrote:
Although I have never had to do this you are able to unlock a iphone by backing it up to itunes, erase it then restore it.
EDIT: http://support.apple.com/en-ca/HT201328
That would not unlock an iPhone.  That's the procedure to do after you've had it unlocked.
NVM, Yes you still need the carrier to unlock.
MacMe
krazykiwi
Deleted
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
Dunkgirl
Where did you buy it from? Your old carrier should be able to unlock it for free.
If you wan to pay for it, there are a ton of services to do it
https://www.doctorsim.com/us-en/unlock-phone/iphone/iphone-x/unlock/
Or jus go to google and type in "unlock iphone X"
