Invalid Sim
sammy2
Hi, I purchased a new Public Mobile SIM card from Walmart today, but when I go to activate it, it says invalid sim. I'm putting in the correct SIM number, I'm not sure what's wrong, please help @CS_Agent 🙂
KMG
You need to send a private message to the Moderator Team so that they can check the SIM number.
If you really want to active at online at home, you are welcome to.  Follow the other thread instructions on trying a difference browser, clearing cache and using incognito mode.
Dunkman
@sammy2
There is a Walmart promotion that if you activate in store with Walmart, you will get $25 credit within 72 hours.  Also, the SIM card is free at Walmart promo too.  With friend referral and autopay, you will get $35 credit if activate in store.
