I phone
Chopper
It doesn’t take a simm card does to iPhones 5&6
Jarvar
@Chopper
Just as an aside. I was impatient when I got my Public Mobile SIM and the kiosk worker didn't have an opener or a paper clip. I eventually found a staple on one of my receipts in the car. I removed it, straigtened it out and held one end with pliers. Just a little way in and the SIM card holder pops out. If that helps.
will13am
Here is the first site that pops up when I searched SIM slot for iPhone.  This is how to open up the SIM tray and insert SIM card into the phone.
https://www.imore.com/how-remove-sim-card-iphone-or-ipad
Jarvar
@Chopper
I don't really understand your issue, but I just got one of those 3 in 1 SIM Cards.
TriPunchSIM_1024x1024
I have the iPhone 5s and I used the Nano punchout.
If you clarify your concern it would be easier for us to find an answer that would suit your need.
NDesai
@Chopper Can you elaborate on your issue? I cannot exactly tell your problem here.
Are you saying that sim card does not fit on your iphone? Or you are not getting any service?
