03-15-2018 06:50 PM - edited 01-04-2022 03:44 PM
I ve boguht an iphone 7 from a friend, who was with TELUS, now inserting my old Sim card from public mobile, says that it cant be used on this before being unlocked, can u help me? IMEI+++++++++ thx!
03-15-2018 09:52 PM
Carrier-locked iPhones are usually unlocked from the carrier-side. As in, they change status information and submit it to the registries, then (when they report the device is unlocked) the end-user syncs the iPhone with iTunes to update device-side status.
Telus is required to unlock the iPhone for you at no cost, and they can do their stuff on the phone or online if you don't want to take your device to one of their stores.
But they are not required to unlock the iPhone - and will actually actively block any third-party unlock attempts - if you owe them money for service or for the phone itself. The device must be fully paid out and "owned" by the end-user before the carrier is required to unlock it.
03-15-2018 07:56 PM
@mathsublime Have a read: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Unlocking-Your-Phone/ta-p/5237
03-15-2018 07:16 PM
My old sim card is till active, I ve bought a new one so my gf can use my old iphone with PM too, I just need to unlock my new iphone and use my old sim car ( same number?)
03-15-2018 07:04 PM
@mathsublimewrote:I ve boguht an iphone 7 from a friend, who was with TELUS, now inserting my old Sim card from public mobile, says that it cant be used on this before being unlocked, can u help me? IMEI+++++++++ thx!
@mathsublime strange result. Since the iPhone 7 came from Telus, it should work on PM without unlocking. Was it used on any other networks by your friend after it was used on Telus? Other thought: you mention an old SIM card from PM. When was it last active? If you ported out the account that was attached to that SIM card, changed your active SIM to another SIM card, or let your account go unpaid for 90+ days, that old SIM card is completely useless (they are single-use only). However, I would expect a different error message if that was the source of the problem.
03-15-2018 06:52 PM - edited 03-16-2018 11:42 AM
Bad news, I'm afraid. If you can't use it for any services immediately with an activated PM SIM that phone is locked to another network, or blacklisted.
