How to swap SIM card from I6 to I6
lkenny
23 REPLIES 23
@lkenny
Read @CalgaryBen 's post about how to set up your APN on your iPhone.
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323118#M24562
@softech
Lol....didn't realize this from the same thread!
lkenny
Hard Reset but still thr same.
Mayor / Maire, got to go to work now but thank you for you help today.
Never give up, is that your moto?
@lkenny  did you try a "Hard Reset" yet?  If not, maybe you should go for a Hard Reset
@lkenny  you tried Reset Network settings as shown on the other post?
Cellular Data Blocked by Network Profile(s) - Community (publicmobile.ca)
 @lkenny : A phone locked by either Telus or Koodo would work here. Did you try the devicecheck.ca mentioned earlier?
lkenny
yes. sync after unlock
reboot, now says "searching"
sync is successful after reboot.
 What else can i do with itunes other than sync?
did you sync AFTER Telus unlocked your phone?
I guess, try reboot your phone once again, try the SYNC again.
Also, are you able to call out or receive calls?
lkenny
So p called Telus and they unlocked id for me
Now top left says no service
Itunes syncs but that is it
@lkenny
Has this new phone been with a previous provider? If so, check to see if it is not locked to that provider. If it is, contact them to unlock it for you.
Check to make sure this newer phone is not blacklisted:
https://www.devicecheck.ca/check-status-device-canada/
lkenny
Was previously used by my son with Telus.
I will check this out.
I assume yours  is not a brand new phone and  was used on another network or for office use.    Have a look at this post regarding remove Profiles that might be setup from before and Reset Network settings
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323130/highlight...
do you at least have voice working now?  just Data is the problem?
lkenny
public mobile 36.0.1
lkenny
OK, i will download itunes to my desktop and do as u instruct.
I will respond with results.
Thank you for you efforts
another question, what do you see if you goto Settings --> General --> About --> Carrier   ?
again, put this SIM into the "new" iphone, make sure Wifi is on
At the same time, also plug into this iPhone into the computer with iTune again to see any update and carrier profile comes down.
lkenny
I take the wotking SIM from one I and plug it into another I6 after having reset all data from the later I6.
It says , top left "searching"
did you have the PM SIM there when you plug in the phone?
What is showing on the iPhone screen, do you see Public Mobile on top ?
lkenny
 have the latest apple uodate, how does one download a carrier update
lkenny
Yes, iphone 6
are you talking about iPhone 6?
If so, you might want to plug in your phone to a computer, launch iTune and download the latest update as well as the Carrier Profile.
lkenny
It is betwi 2 phones.
When in the newer I6, it just searches forever
I6 to I6?  iPhone 6?
If it is between 2 phones you meant, you can simply pull it out from one and put it into another one.
If you have a new SIM Card and you need to swap from OLD to New SIM card (tie your exacting phone number from OLD to NEW SIM card), you will need to open ticket with Mod for a SIM swap request.
