02-27-2020 12:18 PM - edited 01-05-2022 09:40 AM
02-27-2020 12:49 PM
If it's the Samsung galaxy a5 2017, @EmmaJack86 . Then according to this post https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Is-anyone-using-the-Galaxy-A5-2017/td... it will work on PM's network.
02-27-2020 12:43 PM - edited 02-27-2020 12:44 PM
02-27-2020 12:30 PM
A5
02-27-2020 12:23 PM
@EmmaJack86 do you have a phone currently?
If so, which phone do you have? We can tell you if it will work or not.
02-27-2020 12:22 PM
You have to have your own phone. If you shop at Costco, they usually have some budget phones for sale. Usually Samsung or Motorola brand.
02-27-2020 12:22 PM - edited 02-27-2020 12:26 PM
@EmmaJack86 wrote:How do I get a phone n how does it work
@EmmaJack86 Public is a Bring Your Own Device provider. You can purchase phones from Amazon, Costco, Best Buy etc. Then follow this article to get started:
https://www.publicmobile.ca/en/bc/get-started
02-27-2020 12:21 PM - edited 02-27-2020 12:23 PM
Hey @EmmaJack86 ,
Public Mobile has "Bring your own phone" plan deals only.
once you have a phone you can choose a pre-paid plan with PM.
You can order a sim card online or buy a simcard from local stores eg.(Walmart, london drugs)
You can see all the plans offered by PM HERE
Cheers
02-27-2020 12:21 PM
Public Mobile does not sell phones..any phone that is unlocked that is compatible with Public Mobile can be used. Just buy a sim card and put it in
02-27-2020 12:21 PM
Public Mobile doesn't offer phones. You will need to purchase one through other outlets that will sell phones. Costco, Walmart, Staples and online resources as well would be a good place to start looking for the type of phone you would want
