Reply
Re: How do I set up data/APN on my smartphone?
@Julie30wrote:
I have tried those APNs and nothing works, I am trying to get my data and picture messaging to work on my LG G5!! Someone help please !
quote from this Knowledge Base article: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p...
"Lastly, if you have an LG phone and you still aren’t able to use your data after all of this, we highly suggest doing a factory reset of your phone. We have found this to often be the only way to get data working on LG devices!"
@Julie30
On an LG G5 ...
First, Tools > Settings > Network > More > Mobile Networks > Network Operators
Select "Automatic" or "Public Mobile"
Second, Tools > Settings > Network > More > APN Settings
https://apn-canada.gishan.net/settings/1403_15_public_mobile_apn_settings_for_lg_g5.php
Finally, restart the device for changes to take effect.  It may report "Telus" instead of "Public Mobile" for a little while, but this is normal and doesn't affect anything.  Different Android builds sometimes have slight differences in the menu/tab navigation, but the basic options are still somewhere "logical" if you dig around for them.
You might also find this thread useful if you need to factory reset your LG G5.
https://productioncommunity.publicmobile.ca/t5/Discussions/I-can-hear-them-but-people-can-t-hear-me/...
* I am happy to help, but I am not a MOD please do not include any personal info in a private message to me, click here to private message a Moderator *
My phone is have problemshttps://silverbirdng.com/?s=Gionee
Ted
Hell0 all,
Does anyone know the exact APN settings for:
Samsung Galaxy Ace Q (SGH-I827D) ?
..i didnt find it in the list of devices on the website for APN settings..
Thanks.
yes i did that 2 times already still not working
Thank you!
Ive followed the instructions but it still wont work Smiley Sad....any suggestions?
i had to do a factory data reset on a LG-G4 ---- after that it work right away
@RosieMwhat phone are you using?  have you tried a netwrk setting reset?
