Reply
Re: How do I set up data/APN on my smartphone?
posted by mistake.
I've checked and followed all the steps it still not working. Even the people who works in the moblie store can not help me. Is there anyone can help set this up? It has been really frustating.
@shimuzhang  For better visibility you should consider starting a new post. What type of phone do you have? These are the Public Mobile APN settings you need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one.
If you need to know where to find the settings:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Iphone
Settings > Cellular > Cellular Data Options > Cellular Network
OR
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
My phone is Huwei 20
@shimuzhangOk that phone should work with Public Mobile. Are you using 2 sims? Can you post a screenshot of your current apn settings?
In that case I would save all pictures and videos on a memory card! Then do a factory data reset,
That's what I had to do, on my wife's phone. Works Good now. What type of phone do you have?
thank you
