03-29-2019 06:16 AM - edited 01-05-2022 03:59 AM
Hey guys, im helping out a friend who I reffered. He ran his imei number check on the site and it said ok. He ordered and installed the sim, filled out the form (i got confirmation welcoming him as a refferal) but his iPhone 6 says it's locked. He called Bell and asked for it to be unlocked and he got an email back saying it was now done and to install the new sim card from another provider and it should be unlocked but he still gets sim not supported. I tried his sim card in my phone and everything works fine. Really need help here as now he is without a phone. Thanks in advanceeedited by computergeek541: removed screenshot because it not only included IMEI, but also showed name and e-mail address of customer
03-29-2019 10:05 PM - edited 03-29-2019 10:06 PM
@Mountainmaxman wrote:Thanks guys bell sent a second request and unlocked it fine. All good, thanks for the help
I have deleted your screenshot from your message post. Not only did it show your device's IMEI, the picture of the e-mail mesage also contained your name and e-mail addresss. You'll still need to go into the community profile and delete the image from your profile.
03-29-2019 08:18 PM
Great!!! Welcome to public mobile!
03-29-2019 08:17 PM
03-29-2019 11:37 AM
we completely erased/whiped the phone twice, can't check any settings under cellular with the public sim in there keeps getting that warning message as soon as the sim is inserted. before the sim, the screen under cellular is completely blank. No bell store within 300km of us and he has the email saying it should be unlocked but im thinking it is not
03-29-2019 11:25 AM - edited 03-29-2019 11:31 AM
@Mountainmaxman wrote:There are no retail stores where I live 😞
Then you need contact bell again, it looked like bell did'nt unlock your phone.
Edit: Since unlock phone is free, so I won't suggest you pay to unlock, but If you still can't unlock your phone, you can try this service, I tried couple times before, pretty good service:
03-29-2019 11:19 AM
But you can do it on the phone..no? Did you try?
03-29-2019 11:17 AM
03-29-2019 10:12 AM
@Mountainmaxman wrote:Yes tried both ways
You may go to bell retail store, let staff unlock for you.
03-29-2019 10:04 AM
I would say that it looks like Bell never unlocked it.
03-29-2019 09:02 AM
Yes tried both ways
03-29-2019 07:04 AM
@Mountainmaxman Did you try second method to unlock phone?
03-29-2019 06:54 AM - edited 03-29-2019 07:04 AM
@Mountainmaxman On your phone, go to Settings --> Cellular look for Cellular Data Network if you can find this option, then your iPhone is unlocked, but if not, your iPhone is locked.
03-29-2019 06:39 AM
Sounds like the unlock process didnt work correctly...
