Help! Data not working even after APN set? [LGG2 D802]
zetta_big
I've set up the APN like the other posts have suggested but I still dont have data.
Granted, I've just activated my Public mobile account a couple of hours ago but I can talk and text on it, which means everything should have transferred.
I'm using an LG G2 D802 brought unlocked in Hong Kong running stock 4.4(kit kat).
When I try to run a ping test on the service menu, its says:
Ping IpAddr: Fail: IP addr not reachable
Ping Hostme( wee.google.com): Fail: Host unreachable
Also, when I turn on data the phone does not show the standard up arrow down arrow data icon on the notification bar. Pretty much, nothing happens.
44 REPLIES 44
makkahn28
@zetta_big
What was your previous APN settings at? So that PPL know what NOT to do, and enjoy their services unhinged
Great thing, I Just copied what My Phone APN Info stated, so that in case PPL had issues like this, I have an answer for that
That's Good
Also, IF you wish to use your Handset as a Tethering Device as well, I posted the Info too
zetta_big
thanks for the alt APN settings! Worked! Accepted as solution and bravo'd.
If you tried these settings, then that means that there is something wrong then
Send an Email to Public Mobile
Looke for Contact Us
Scroll till you find Email away
Click Technical Issues
Click Data not Working
Click not receiving signal
Click Email US
An Application form pops up
Fill-in all Info, Name PM # Brief Description on your technical issues
Within 24-48 HRS, a PM Rep will Email you back with a response
@zetta_big Looks as if you've set everything correctly. Two tests to suggest:
- can you send/receive picture text msg,
- can you connect to internet through a wifi connection?
zetta_big
mekkahn, I've said so on my post that i have tried the Public mobile settings. MY phone supports HSDPA 850 / 900 / 1900 / 2100 - D802 bands so it should at least connect to the 3G network.
I will try the mobile internet settings, will report back.
This is for the Tethering, if you wish to use your handset to tether:
Here's the APN (Access Point Name) Tethering info if you wish to use your handset as a mobile Tethering Hotspot
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
Authentication type: Not set
APN type: dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
If Android, Here is this:
If Handset fails to connect to Carrier Data or MMS does NOT work, Your APN (Access Point Name) Settings are Not Set to Public Mobile's settings.
Here's how to edit, so that your handset can connect:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Is Phone Android? Windows?
Lastly, DOES THIS phone support the HSPA+4G Network's Frequency spectrum?
3G: 850/1900 MHZ   This is the BARE MINIMUM required for Talk+Text+Data Services
4G LTE: 1700/2100 MHZ
zetta_big
as said in my post, the phone is unlocked and i am able to call and send texts.
Also is the Phone UNLOCKED?
makkahn28
Hi. Does this Phone even work? Are you able to Call, receive Calls, Send out Texts, or Receive Texts?
