Reply
Highlighted
Re: Gsm
Its a 2020 new cell phone
With finger print and face recognition
Highlighted
Re: Gsm
It only says S30 2020
Highlighted
Re: Gsm
It says it works on 4G LTE and 5G. So likely, it will work with Public Mobile, but not sure fully or partially with some frequencies. For this reason, you must find out its specifications. If you can't, there are other phones out there for that price as mentioned by darlicious.
_________________________________________________________________________
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
Highlighted
Re: Gsm
@AdamLove
There are lots of members with umidigi phones including @will13am  @popping  @gblackma   @Clive  @justicebeans  @CFPartDeux  and a few others...the A5 pro is reg $175 with case and screenprotector $130 on a lightning sale taxes and shipping included. A phone on wish that doesn't tell you the brand is always worrisome.
Highlighted
Re: Gsm
@darlicious wrote:
@AdamLove
There are lots of members with umidigi phones including @popping  @gblackma   @Clive  @justicebeans  @CFPartDeux  and a few others...
Not me.....
Highlighted
Re: Gsm
@CFPartDeux
My apologies I must have mixed you up with someone else!
Highlighted
Re: Gsm
@darlicious wrote:
@AdamLove
I treat my A5 Pro as disposable phone as it is expensive to send my A5 Pro to China for warranty repair or replacement.  Don't compare A5 Pro against the flagship phones.  It is mid level phone at entry level price.
It is nice that UMIDIGI supplies the screen protector and case.  When I got it in November, the camera did not past my test.  After a few firmware updates, the camera is getting better.  Please note that my camera expectation is low.  The volume was not high enough during a phone call.  I found an instruction on adjust internal settings.  It is fine now.  It you don't want to change the internal settings, you can install Volume Booster GOODEV app.  I am still happy with my purchase after 6 months.
Highlighted
Re: Gsm
@popping
      Of the limited time I had to use the camera on the A5 pro until the bf lost it I was pretty happy with it with the exception of the poor low light capabilities. Mind you it couldnt compete with my galaxy A3 but has some good qualities that I think the average user would be pretty happy with the cameras capabilities. If bought at the $130 price point compared to the load of crap at that price point like the Maxwest or an RCA priced even higher or many other phones.....its an excellent deal. Spend $100 more and get a deal on the F2 and youll be really happy.
    The repair in China problem is easily solved with the purchase of the phone on a credit card with device insurance. Originally I was going to make a claim to replace the cracked screen when the bf dropped the phone (on concrete) once he stopped using the protective case (dont ask) but he managed to lose it 3 weekes later. Im awaiting my cheque $112.90 ($10 deductible +2% of value per month.)
Highlighted
Re: Gsm
@darlicious
Good point about the buying with credit card with extended warranty insurance and first 3 months buyer protection. Unfortunately, I purchased my A5 Pro with GC on Amazon.  I will remember to use my cc to buy another UMIDIGI mid level phone.
Highlighted
Re: Gsm
@AdamLove I'm confused.  The model is S30, but what's the brand of this phone?
