09-22-2019 05:02 PM - edited 01-05-2022 07:14 AM
I have a Friend that's a 1st Timer, with a Cell/Smart Phone.
I got a couple of Phones, (a Smart Phone) from a Friend to give to him.
Intested in the P.M.Plans, but need to see if the phone is Unlocked or Not?
There's NO SIM CARD in the HTC Raider, so is it wise to buy one without knowing if the phone can be used? Or do I need to have a SIM CARD to see if the Smart Phone can be used and if it's unlocked?
I do get the IMEI
There's 2-3 Options for Networks. But You probably can't make a Call, if the Phone has No Plan with a Carrier - or SIM CARD.
I don't want to bother, a Friend of a Freind, to call to unlock the phone
___________________________________________________________________
I also have 2 Flip Phones, 1 from Koodo and another from Bell.
They both just say searching for Service when turned on....
So these don't take SIM CARDS....so what is done with activation...just enter an ESN? or can they be on the Network.
Also *#06#.does not give IMEI.
_Thanking you in Advance for Your Help. ___________________________________________________________________
09-22-2019 09:45 PM
Refurbed phones are usually as good as new - sometimes they're "factory" repairs, sometimes they have insignificant cosmetic defect/damage, sometimes they were returned just hecause the first buyer didn't like the product - many people are willing to pay premium for utterly perfect and idealized devices - but if you're not fussy then there's nothing wrong with paying less for a phone that has nothing wrong with it.
But refurbed boxes are usually "special deal" "as-is" items, no return/exchange unless the item simply doesn't work. The best bet is to test it out in the store, don't walk out with it before you know it works. Still better odds than you might find on craigslist.
If you're not in a hurry then check the PM Announcements every week or so, they frequently run ad-hoc weekend promos and stuff so you might be able to score a free PM SIM card and simply sink $10 or $15 into the cheapest Plan available.
(and if you can get referred by an existing PM customer then you can also get a $10 credit, won't cost you anything extra but if PM works out for you then that extra ten bucks doesn't hurt.)
09-22-2019 08:20 PM
@Darren_M wrote:I found this tool to check Phone and Network Compatabilty too....
https://willmyphonework.net
If you still haven't determined whether your phone would be compatible, your best option would be to do as suggested by @Korth and go to a Telus or Koodo store to confirm that you can use it with PM.
If it turns out you need to buy a another phone, depending upon your needs, you can easily get an inexpensive smart phone (Motorola are pretty decent phones and not overly expensive), or even a flip phone such as Alcatel GoFlip will work with PM and is around $80. I tend to steer clear of used phones unless I personally know the person selling the device, but maybe a factory reconditioned one might also be worthwhile considering too.
09-22-2019 07:20 PM
09-22-2019 07:18 PM
Take the phone to a Telus store or a Koodo store. They can test it with one of their own active SIM cards... and it will work or it will report "Invalid SIM" (because it's carrier-locked) or it will simply be incompatible technology.
They'll try to sell you stuff, of course, but you are not obligated to buy so it won't cost you anything.
You can buy unlocked phones from London Drugs, Staples, Canada Tire, Walmart, and other places. They're unlocked so they will work on any carrier and don't have to explicitly promise compatibility with Public Mobile.
You can buy used phones on craigslist or facebook market. But sellers aren't always savvy (or honest) enough to guarantee the device is unlocked. And diminished battery life becomes a concern on older devices so you might have to include price of replacement battery (usually about $25 to $45+) ... which makes a decent $75 new unlocked phone seem like a more solid deal.
09-22-2019 06:51 PM
@Darren_M wrote:Thanks for ALL Your Replies Everyone...
This Smart Phone and Newer Network Tech. is NEW TO ME.
I was going to ask if someone else's SIM will Work in Any Phone...
So I guess I can try Another PM SIM CARD, but if it's NOT a PUBLIC MOBLE SIM it Can't be Used... The SIM CARD IS SPECIFIC TO THE NETWORK and CANNOT BE INTERCHANGED?
What about Cleared like an SD CARD?
To test your HTC Raider 4G whether it will work with PM or not, you need to find someone who has Telus, Koodo or PM SIM card.
09-22-2019 06:46 PM - edited 09-22-2019 06:49 PM
I guess If I had another SIM CARD I could try it - but if it's NOT a PUBLIC MOBLE SIM it Can't be Used?... The SIM CARD IS SPECIFIC TO THE NETWORK and CANNOT BE INTERCHANGED?
Can it be Cleared like an SD CARD?
09-22-2019 06:40 PM
@Darren_M wrote:That's some of the Dilema i'm having about "Getting Started".
*I have to have a SIM CARD and PLAN to make a Call
*There's No Certainty that if I buy a SIM CARD for the Phone it will work on P.M.
* Is it Possible that when I create an Account with a Phone/SIM and Plan that Public Mobile will take my money for the Plan if the Phone is Locked and I can't use it / OR will I Not Be Able to Complete the Order and Account for Service?
*Do I need a Plan and SIM CARD to find out if the Phone will Work on the Network.. If so the Cost of the Plan will have been a Waiste of money... till i find a phone that will work on the network.
Find a friend with a Public Mobile account and try their sim in your phone.
09-22-2019 06:38 PM - edited 09-22-2019 06:42 PM
*Do I need a Plan and SIM CARD to find out if the Phone will Work on the Network.. If so, the Cost of the Plan will have been a Waiste of money if the phone is Locked... till i find a phone that will work on the network.
09-22-2019 05:46 PM - edited 09-22-2019 05:54 PM
I'm ALMOST 100% Positive the Phone with with Bell/ Aliant in N.S. and Under Contract which EXPIRED years ago.
I believe RODGERS or /TELUS was one of the Network Selections... But I given the phone to my Friend and would have to verify that.
09-22-2019 05:42 PM - edited 09-22-2019 05:56 PM
I thought I seen a notice about the Frequency to check compatability with P.M. on the SITE - but can't seem to find it again...
Your Comment with a link makes some sence to me ....but I really can't interpret or compare without knowing what frequency the phone is = and that which is used by PM?
I do remember my friend took out the SIM Cards and I'm Pretty Sure it had 4G but I believe it also had LTE?
09-22-2019 05:39 PM - edited 09-22-2019 05:52 PM
@Darren_M Only the Rogers version of the Raider will work on Public Mobile; if it's unlocked.
HTC Raider 4G - Canada, Public Mobile
09-22-2019 05:37 PM
Yes...you'll need a sim to see if the ophone is locked to previous cell provider. If it was used on one of the networks as suggested by @dabr , it'll work at Public Mobile.
09-22-2019 05:34 PM
@Darren_M wrote:There is CURRENTLY NO SIM CARD AND NO CARRIER
Is a SIM CARD NECESSARY to see if the SMART PHONE is UNLOCKED?
Yes, the easiest way to see if the phone is unlocked is trying a sim card in it.
09-22-2019 05:32 PM
You HTC Raider may not work with PM according to the following link.
PM use 3G singal for voice call. This phone may work with some PM LTE signal depending where you are. It is better to look for another phone for your friend.
https://www.frequencycheck.com/carrier-compatibility/6KQfq/htc-raider-4g-htc-holiday/telus-canada
09-22-2019 05:28 PM
09-22-2019 05:26 PM
@Darren_M wrote:
Do I need a SIM CARD, to see if the Smart Phone is Unlocked?
Yes, as far as I know.
09-22-2019 05:23 PM
@Darren_M wrote:There is NO SIM CARD, (My friend removed his SIM CARD which was with another Carrier)
The Other 2 FLIP PHONES Do Not Take a SIM CARD. so Can they be Activated with just the ESN?
Your phone needs to support SIM card in order to use with PM.
You can use your SIM card to test the SIM card phone.
Which provider are you using?
09-22-2019 05:20 PM - edited 09-22-2019 05:24 PM
The Other 2 FLIP PHONES Do Not Take a SIM CARD. so they CANNOT be Activated with just the ESN?
09-22-2019 05:17 PM
@Darren_M Try your SIM card in each of the phones to confirm compatibility. 3 friends reported liking getorchard.com for used phones.
09-22-2019 05:12 PM
@Darren_M wrote:I have a Friend that's a 1st Timer, with a Cell/Smart Phone.
I do get the IMEI
There's 2-3 Options for Networks. But You probably can't try to make a Call, if the Phone has No Plan with a Carrier - can you?
You need an unlocked SIM card phone in order to use with PM. The old CDMA phone will not work with PM any more as Telus had turned off the CDMA signals a few years ago.
09-22-2019 05:07 PM - edited 09-22-2019 05:12 PM
I do get the IMEI
Phones that worked with Bell or Koodo should be fine. You can check for compatibility of the phones here: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwjgh4ncquXk...
You won't be able make calls without an active SIM/plan in the phone.
