Dtek 50
JW2
Has anyone been successful using blackberry dtek 50 with PM looking to change may parents over just want to make sure there hardware will not have any issue (radio frequency look like they area compatible)
13 REPLIES 13
My first public mobile port was to DTEK50 for my wife. Phone was formerly on the SaskTel network, so it should be the same model as Bell in the rest of Canada. It works swell, and even supports HD Voice calls to other Telus/Koodo/PublicMobile customers.
StephHfx
Yes this phone is great and works fine on Public Mobile.
@JW2 wrote:
I will need to find out if it's unlocked
Just call bell with IMEI number handy and ask for the code
It would be best to insert non bell sim like public Telus o or Fido to have the exact error message.
JW2
I'm in Ontario
JW2
GinYVR
@JW2Since Public Mobile uses Bell towers out East, the phone should work fine provided it is unlocked.
JW2
Bell is the previous provider it is a Canadian version of the dtek
kerago
Definitely should work!
cellphoneuser1
@JW2 careful about different worldwide variants. Some models have multiple frequency configurations.
Lorca
As @totalUser said, try using your Public SIM card with their phone, if you're with Public mobile.
BTW, if your parents aren't too computer/self-serve savvy Public mobile might not be a great fit for them. Some people are content paying more each month to have small issues taken care of by an easily available representative.
totalUser
Hi
Are you with public? Can you test your sim inside? If not do you have any friends or colleagues who wouldn't mind doing it? You can also take the phone to koodo or telus store and ask them to try it
In general i would trust the information about the frequency, but since you are doing for elderly you want to make sure that they don't have to tweak apn settings or anything like that as well as getting puk code after they have switched, you want to do that before.
Btw who is the previous provider?
Triguy
According to https://willmyphonework.net/ it should be compatible with PM.
LovesToPM
Yes it will work well.
https://www.kimovil.com/en/frequency-checker/CA/blackberry-dtek50
