01-05-2015 03:57 PM - edited 01-04-2022 12:30 PM
Dropped calls can happen when moving into a low signal area or driving out of coverage. If the problem happens more frequently and in various different locations then it may be phone related. Refer to the tips below:
Does the problem happen when using one of the following?
Try using your phone without the accessory.
If the phone powers off when the call is dropped the battery may be loose. Check to make sure the battery is inserted properly.
