Does the Ulefone Armor 8 work with Public Mobile?
Jor9eMartinez
Hi,
I'm planning to buy a rugged phone but I think the compatibility tool is outdated. Does anyone know if the Ulefone Armor 8 would work with Public Mobile?
Specs:
Triguy
Public Mobile utilizes the following frequency bands:
4G LTE and LTE Advanced:
700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS)
HSPA:
850 MHz and 1900 MHz (UMTS)
@Jor9eMartinez
Amazon.ca has a lightning deal starting in about 15 minutes for this model priced at $271.99.
https://www.amazon.ca/Ulefone-Armor-Waterproof-Smartphones-Smartphone/dp/B08LD1CH24/ref=pd_di_sccai_...
Yes will working 100%
for public mobile phone compatibility
you have to put it a device brand for any phone to you can see all information,
you can visit here >>
WillMyPhoneWork.net - Check if your phone works on a network
following  >> To find out if your cellular phone is compatible with our network, click  HERE
visit Here  to you can full information about your device.
Good Luck
 @Jor9eMartinez : From those specs, yes.
