Deleted text message
Tinamarie
Can I retrieve a deleted text message after 48 hrs
keaiman
I am not sure, cause if the deleted text messages were overwritten, it's impossible to recover them back. Just try phone data recovery scan your phone, if the deleted text messages can be scanned out, they will be displayed. Then you can choose them to recover at ease.
@yale45 wrote:
Hi there,
Before retrieving the text messages,I recommend you to check if the deleted text message has been overwritten by new files by using MobiKin Doctor for Android free trial version.If not,then you can use it to retrieve them easily.
I don't think that anyone is paying attention to this thread any longer. It's from June.
yale45
Hi there,
Tony8
GinYVR
@TinamarieI don't think Public Moble has provision to do that.
