Data won’t turn on without a reboot
Ron112355
Would like to know why I keep having to do a network reset whenever I need to use my data. I don’t use it often but would like to not have to reboot when I do.
Hoping it’s a simple fix as am not that technical..
Tia
11 REPLIES 11
DOA
Android 6 is really, really old, but apparently ATT did update it to Android 7.
I'm not sure that update is available to you in Canada, but you can check.  It may not fix it, but what have you got to lose?
https://www.att.com/device-support/article/wireless/KM1147672/Samsung/GalaxyJ32016
@Ron112355 wrote:
Phone is a couple of years old, probably time to upgrade but money is tight and weed is legal so it’s been tough to prioritize lol
This phone was released in 2016, so it is old but not that old.  It seems like maybe the AT&T bloatware is not playing nice.  That is a problem with carrier brands sometimes.  For $200, I would have gone with other budget brands.  My Umidigi F2 was less than $200 and it is less than 1 year old.
@Ron112355 wrote:
Really not sure on that one sorry🙁
@Ron112355  When replying to a post, if you start with @, a list pops up and you can click on the person you're answering. If you also click on the 3 dots just above the open message window (beneath "PREVIEW", it will expand the options available to you. Click on the quotation marks and we will know what you are answering. What aren't you sure about?
Ron112355
Ron112355
@Ron112355 Or maybe try a factory reset of the phone (caution, this will reset everything and erase all of your data so make sure the important stuff is backed up).
@Ron112355
  • go to the play store and update all your apps, particularly the carrier services app.
  • enable/disable airplane mode instead of resetting your network settings
  • factory reset your device
will13am
This sounds like a software issue.  Not sure what to suggest, perhaps do a warranty exchange or refund if that's an option.
@Ron112355 Does everything else works fine without having to do a reset? Including MMS?
Ron112355
Thanks for the tip
I am poor so am using a Samsung -SM-J320A
Android version 6.0.1
I bought it unlocked for $200 was originally mfg. for A.T.T. Customers so it’s got their crap on it that I can’t get rid of to free up space.
kb_mv
@Ron112355 It might be helpful if you told the community what phone model you use. Sometimes issues can be device specific.
