@TmanAccording to the specifications here the Nokia 3310 won't work with Public Mobile
Network speed 3G
Network bands GSM: 900, 1800; WCDMA (FDD I, VIII)
Try checking your APN Settings. Not sure what OS your Nokia runs, but...
For Android, click:
Settings > More / More Networks / Wireless & Networks > Mobile/Cellular Networks > Access Point Names >
These are mine:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
@Tman Try this to learn to adjust apn settings?
Network speed 3G
Haha well actually I switched from a smartphone to this one and I don't plan on going back soon. I do appreciate the challenge of downgrading in life. Slowing down, perceiving the world in a backwards perspective. Brings to light a new perspective on the things I once had, and helps to maintain control.
@Tman wrote:Haha well actually I switched from a smartphone to this one and I don't plan on going back soon. I do appreciate the challenge of downgrading in life. Slowing down, perceiving the world in a backwards perspective. Brings to light a new perspective on the things I once had, and helps to maintain control.
Agreed. What plan are you on? You probably only need the $15 w/the $5/500 min add on for back up. I do subscribe to the smart brain stupid phone club.
@GinYVR wrote:@TmanAccording to the specifications here the Nokia 3310 won't work with Public Mobile
Network speed 3G
https://www.nokia.com/phones/en_ca/nokia-3310-3g#details
Me too, prefer basic phones over smartphones. How can I search for ways to setup MMS on INQ Chat 3 and Nokia 6650. Calls+ SMS do work on both phones. Thanks in advance!
@Montrealpost wrote:Me too, prefer basic phones over smartphones. How can I search for ways to setup MMS on INQ Chat 3 and Nokia 6650. Calls+ SMS do work on both phones. Thanks in advance!
I'm not even sure that the Nokia 6650 is compatible with Public Mobile. The search that did says that would need a Nokia 6651 for UMTS Band.2.
