Data help for new refurbished IPhone SE
brindlefly
Hello.  I'm unable to get data.  Wifi, text and calls are fine.  Checked the advice on APN, but in Settings under Cellular it just lists APN, User name and Password.  Tried the site to download the configurations and it said to open and accept configuration under Settings App, but there is nothing there.  Can someone help?  Last phone I had was over 10 years ago, and I'm beginning to remember why!  Lol
44 REPLIES 44
brindlefly
@gblackma wrote:
@brindlefly , @Popololo  uused this site to fix the apn settings on an iPhone see link here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
This link opens a private message box.
brindlefly
@iPhoneUser wrote:
Check account to see if you have data available to use.
With the ISP setting.
Re seat your SIM.
Reboot iphone.
Does it work?
No work.
Reset network settings. (Causes loss of memorized wifi passwords, change name of phone, turns data switch on)
Reboot iPhone.
Try data.
Does it work?
Check for apn.....SP or ISP?
Please  advise results.
Tried all and still no data.  Checked APN again and it reads isp.mb.com
iPhoneUser
Re seat your SIM.
Reboot iphone.
Does it work?
No work.
Reboot iPhone.
Try data.
Does it work?
brindlefly
@iPhoneUser wrote:
Does your phone say:
sp.mb.com
or
isp.mb.com
If sp.mb.com........try adding an i ........isp.mb.com
Just press the field to allow and edit and change and try your data.
Mine is the same as yours, with the isp.  I went back and tried with just the sp but neither are working.
iPhoneUser
sp.mb.com
or
isp.mb.com
brindlefly
@iPhoneUser wrote:
I just tried the website for my iPhone SE. Where would I find the download? Or should it be an option of selecting and APN setting? Or is it obvious that it does not work for an SE?
This exactly where I'm at.  I cannot find the download either!
iPhoneUser
I am now am now wondering why I even set up my iPhone SE with “ISP”.  I must have found it somewhere. It works. Any other iPhone SE owners out there? What is your setting?
The NZ website says: “SP”462BA5CC-1C26-42DC-8F9B-3319534105BF.png
The PM website says: “SP”
My setting: “ISP”
iPhoneUser
Thanks @ShawnC13 , I totally missed that.
@ShawnC13 wrote:
@gblackma , it is in the subject title refurbished iPhone SE
iPhoneUser
Here are my iPhone SE settings....and data works.
ShawnC13
Early iPhone APN settings cannot be updated manually. You will need to connect to wifi, access http://www.unlockit.co.nz/mobilesettings/ with Safari, then follow the directions there. pasted from @Luddite's quirks thread.  Now I am not sure if this will work on the SE if it is considered an early iPhone
gblackma
@brindlefly  what's the  make and model of your phone?
