Reply
Re: Connectivity issues after upgrade to android 8.1
@MJH, can you add another APN with just the modifications/additions you require?  I've done this on my device as I can't modify the primary APN file.
@MJH wrote:
Still not able to input APN settings.  Thankfully I have another phone which has Android 8.0 so I am using that.  I guess I'll have to contact CRTC as suggested by another PM user.  I hope I don't have to switch carriers but will if this problem isn't fixed.
CRTC's a little drastic. This is a known issue with Android 8.1 on some devices.
Seems the preferred fix is to insert a SIM from another provider that would open up the APN settings and then put back the PM SIM.
There are other more convoluted technical solutions but the SIM seems easiest with least disturbance.
Try using the apk developed by a RFD member.  Disclaimer, I have not used it myself.  It has been reported as a working solution.
https://forums.redflagdeals.com/solved-fido-apn-miui-10-cant-add-apn-2239645/#p30122708
HAL
I had the same problem 8 days ago after receiving an update.
I took my Zenfone 4 Max Plus to the Asus service depot and they confirmed that there was a problem with the update and that the only solution was to go back to the previous version. They are working on the issue and will resend the update when reworked.
This process however resets the phone to factory settings, so backup your information.
In addition, after this reset you have to re-enter your APN on the phone.
https://apn-canada.gishan.net/en/apn/public-mobile/asus-zenfone-4-max-plus-zc554kl
Hope this helps
I can confirm that the linked APK worked to manually set up an APN on an Asus Zenfone 4 Max. Did this with SIM out, then inserted SIM and it was good to go; the manually added APN had been selected, and data worked.
Still puzzles me why Android authors/maintainers would remove that manual APN add function.
Thanks to contributors to this thread for helping me find the solution.
