01-13-2019 07:15 PM - edited 01-05-2022 03:02 AM
Just joined Public all is cool but cannot send or recieve texts from my Bell peeps. Please advise we came from Virgin and it worked there can call them but no texts hopefully just a setting can be adjusted i have Samsung neo5 and my wife has samsung s4 same issue. TIA Kal
11-17-2022 06:22 PM - edited 11-17-2022 06:23 PM
I'm having the exact same issue with my Pixel 4, coming over from Virgin. I don't yet know if this issue extends to all Bell users but I just discovered that I can't send or receive texts to my buddy and upon testing verified that I can't send or receive texts from my work phone on Bell. How did your issue get resolved? Sending to and receiving to devices on Telus / Koodo are fine. Been ported for a while now, probably a week +.
01-13-2019 10:54 PM
I hope it works by now a similar thing happened to me with bell, not receiving calls or texts found out later it was just my mother ignoring me
01-13-2019 09:03 PM - edited 01-13-2019 11:43 PM
@slash407 wrote:did it work by now? try changing the settings in messaging if it didnt. I highly doubt its only bell messages ur not receiving.
Why do you doubt it? All we can go by is what the OP tells us.
Please note that when someone has a problem with sending or recieving text messages, it very often is to and from just one specific carrier. This is actually fairly common.
When a text message go from one carrier to another, it does not go directly there. It first gets routed to an intermediary third-party company who then relays the messages to the destination carrier.
When someone says they aren't receiving text messages from some people or some people aren't receiving sent text messages, the very first thing that I think of and ask is if it is a problem only to one carrier.
When it is a problem to or from just one carrier, there isn't anything the user can do to fix this. There are no possible settings that could possibly block any and all text messages, but only from one carrier. This is something at the cell phone carrier's end, and must be fixed by the moderators.
01-13-2019 07:27 PM
Is it only to people on Bell? Have you tried to contact others on different networks?
01-13-2019 07:24 PM
@Kaltireman wrote:Just joined Public all is cool but cannot send or recieve texts from my Bell peeps. Please advise we came from Virgin and it worked there can call them but no texts hopefully just a setting can be adjusted i have Samsung neo5 and my wife has samsung s4 same issue. TIA Kal
Did you just port over from Virgin? It can take 2-4 hours for the port to complete and everything to start working.
