06-21-2019 08:05 AM - edited 01-05-2022 05:29 AM
I can't not receive incoming calls or texts I didn't port a old number I was getting calls and then it stopped..
06-21-2019 08:48 AM
@Howsyourmuffler wrote:I can't not receive incoming calls or texts I didn't port a old number I was getting calls and then it stopped..
@Howsyourmuffler If the problem is only with incoming calls and texts then I would recommend trying your sim in another phone to see if it works. If yes, then it would indicate a phone/setting issue
06-21-2019 08:17 AM
You can try going to your settings and under Wireless & Networks, click More.
The click on Cellular Networks and then Network Operators. Then select "Public Mobile".
If that doesn't work, power off your phone and remove the SIM. Re-insert and power on.
If you still have problems then you would need to contact a moderator.
Moderator can be reached at
06-21-2019 08:15 AM
You can try this...Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone.
Let us know...
06-21-2019 08:10 AM
Are you able to check your Self Serve account? Does it show Account Status: Active?
Which plan are you on and was it recently renewed?
Do outgoing calls and text work?
