04-19-2020 01:47 PM - edited 01-05-2022 10:26 AM
Never been a problem before, but for some reason I can't make calls using the dialpad, but I can make calls if I place the call through the recent or contact menus or my messaging app! Dialpad itself functions but when I press the "phone" icon to place the call I get the message "No cellular network available. Connect to an available Wi-Fi Network to make calls." Samsung Galaxy S7...
04-19-2020 05:17 PM - edited 04-19-2020 05:18 PM
@Maddog I have a setting in my dialer app. it's called "Assisted Dialing" check to see if it's enabled. It automatically predicts and adds the proper country code.
04-19-2020 02:52 PM
@Maddog Did you try restarting phone, turning off and on air plane mode? It seems to be a phone issue rather than PM's. Do you have another Sim of other provider or also PM's so you could test?
04-19-2020 02:19 PM - edited 04-19-2020 02:21 PM
@iliketotalk Yes I have, thank you.
04-19-2020 02:09 PM - edited 04-19-2020 02:18 PM
@Maddog Check the settings on your dialer app it sounds like it's configured to use wifi calling.
Also make sure you haven't setup the default dialing app to be a wifi calling app.
04-19-2020 01:58 PM
@Maddog try turning your WiFi off and see if it works. If it does, try resetting your network setting and restarting your phone. Reenter the WiFi and retry the call again using the keypad. Let us know if this doesn't work. Thanks. Stay safe.
04-19-2020 01:54 PM - edited 04-19-2020 01:55 PM
@Maddog Have you tried putting a 1 in front of your phone number that you were dialing
