10-12-2019 04:59 PM - edited 01-05-2022 07:32 AM
10-14-2019 04:49 PM
If you login to your account does it show if your account has been suspended or not? If it is then you need to make a payment.
If that's not the case it could be a hardware issue. You can also try contacting a moderator here to see if they can help you as well to.
Good luck
10-12-2019 10:01 PM - edited 10-12-2019 10:02 PM
@Topgun if you pay by credit card, check your statements to see if payment was made. You said since August so did it not matter much because you don't use it much? Check if 3g network is enabled required for calls.
10-12-2019 05:53 PM
Try the lost/stolen phone trick to provision your plan feature.
. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
Report result. Thanks
10-12-2019 05:09 PM
@Topgun we're going to need more information about that! Can you log in to your self serve account and check on your plan and if it's active and if it's paid up
10-12-2019 05:09 PM
@Topgun If have them included in your plan, do text messages or data work? If you log into your Self Serve account, what does it say your plan status is?
