Can't get data on my Motorola xt615
Lynn1
Have new account and have not been able to get data on my phone, though the data indicates it is switch on. I can't access the net for anything, maps, gmail, etc.
8 REPLIES 8
@water_marked wrote:
@Lynn1 That phone supports frequency bands 850 and 1900 (@Lachlan_M) which means it should be fine for 3G use with Public Mobile.
Go to menu -> Settings -> Wireless & Networks
Somewhere in there you should be able to make the necessary changes to connect.
You will need to find where to edit your APN settings.
Let us know if you get it sorted out!
Good Luck
It's not just frequencies. It's transmission protocols as well. I think you might be looking at the GSM protocols which is 2G not the 3G ones like UMTS or WCDMA or HSDPA. But who knows maybe I'm mis-reading things.
water_marked
Good Luck
laidlaw1
Make sure to go to the following line https://apn-canada.gishan.net/en/#motorola and have your APN settings correctly entered so that you are able to use your data on the Public Mobile network! This should help you out! Best of luck
geopublic
@Lynn1  Did you purchase that phone from Virgin?
Is it working for voice? gsmarena seems to suggest it won't work here. Nor data.
Oh it's Motoluxe. willmyphonework.net says it won't work either.
charliejohnsone
Make sure your apn settings are set up for public mobile.
hairbag1
Were you able to get the data to work ?
GinYVR
Hi Lynn @Lynn1
Just to make sure your phone is working okay ie can dial and text etc.
Have you put in the correct APN for Public Mobile for your phone? It can be find here.
