Can't access my mobile data on my new phone
jeffguy124u
I recently had to purchase a new phone as my old phone suffered severe damage after being dropped. I purchased a Samsung galaxy 3.  Everything works fine, calls, data & wifi. However, i cannot access my mobile data, data isbpartbof my plan and has not been entirely used. I'm sure its a setting, I'm just not 100% sure where to make changes in my phone to correct the issue. I would really appreciate if someone could send step by step instructions, or just send a link that will help. Thanks in advance!!! Happy holidays to all !😊
2 REPLIES 2
srlawren
@jeffguy124u given that the 3 series Samsungs are now several years old, I'm assuming you obtained this phone used and not new.  If that's the case and it was used on another network previously (Wind/Freedom usually being the offender, but it could be literally any other provider that causes the issue), you may need to do a factory reset to get the data flowing.  Make sure you back up anything important that isn't already backed up or sync'd to a cloud service first, since the reset will wipe your phone clean.
mimmo
you need to set your APN settings
check out this link
Edit: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Managing-your-data-usage/ta-p/152760
step 3 is the most relevant
