Reply
Highlighted
535
Calls go straight to my PM's voicemail
Hello community.
I have a frustrating situation.
When I call my PM number from this number (343-882-xxxx) the calls always GO STRAIGHT to the PM's voicemail greeting (preceded by the beep), and my Cellphone doesn't even ring.
Why is that ?
If the call is from 343-882-xxxx but to other numbers that are not my cellphone, then it's fine.
If the call is from numbers other than 343-882-xxxx, to my cellphone, then it's fine too.
Could someone in the hierachy help me please.
Thank you.
Highlighted
Re: Calls go straight to my PM's voicemail
@535 wrote:
Hello community.
Why is that ?
Thank you.
Is that number in your contacts? And did you block receiving calls from that contact?
