04-25-2019 02:18 PM - edited 01-05-2022 04:36 AM
I am getting calls from unknown numbers with the name as "No Caller Id".How can I block such calls?
04-26-2019 08:59 PM
Open your dial keypad click on the three dots on the top right-hand side then click settings then click, call blocking, then click block unknown numbers or you can manually enter the number that you want blocked and confirm and you're done
04-26-2019 08:55 PM
Click on the number that you want to block scroll down the list go to call details click on it then click on block number
04-25-2019 04:05 PM
there is no "Block Caller" at the bottom.
04-25-2019 04:01 PM - edited 04-25-2019 04:06 PM
@Milk wrote:
@kiyer315 wrote:I am getting calls from unknown numbers with the name as "No Caller Id".How can I block such calls?
Very easy to block callers --- on the phone screen go to recents - then touch the exclamation mark next to the number you wish to block and another menu will appear -- scroll to the bottom and you will see "Block this Caller" -----------
Unfortunately, that's not going to work if there is no phone number displayed. Unknown caller/caller ID unavailable/Caller iD restricted are things that phones sometimes display when there is no phone number information to show.
04-25-2019 03:54 PM
@kiyer315 wrote:Phone model is iPhone 6s Plus.Model # MKV82LL/A.
I checked in settings but did not find any option to block..
Very easy to block callers on iPhones --- on the phone screen go to recents - then touch the exclamation mark next to the number you wish to block and another menu will appear -- scroll to the bottom and you will see "Block this Caller" -----------
04-25-2019 03:52 PM
04-25-2019 03:32 PM - edited 04-25-2019 03:33 PM
I have very little experience with iOS, but it can definitely be done in one way or another. Whatever method used, the calls don't actually get blocked completely, but rather such methods attempt to minimize the amount of time that you speed dealing with these calls.
I know that on my Samsung phone running Android that there is sotware pre-installed by the manufactuer to automatically send all calls from unknown numbers/call ID restricted to voicemail without your phone ever ringing. However, this does not prevent the person from leaving you a voice message.
The are other phone models out that there that will only allow you to auto send calls to voicemail using the stock set up if you know the number and have it saved in your contact list.
There are third party apps out there that do have settings to answer calls and hang up on the person. Some of these apps do have settings to do that even to callers hiding behind unknown number. The person will not be able leave a message after that is done. One disadvantage to this method is that the phone will usually ring once for a split second. Also, this will count as a completed call that you answered, usage-wise.
I am certain that there are anti-spam apps available in Apple's app store.
04-25-2019 02:46 PM
04-25-2019 02:41 PM
@kiyer315, check this link out. It tells you to setup two contacts. "No Caller ID" and "UNKNOWN" and block the contacts.
http://osxdaily.com/2016/11/10/block-unknown-callers-no-caller-id-iphone/
04-25-2019 02:40 PM - edited 04-25-2019 02:41 PM
I don't think it's possible to block unknown numbers
04-25-2019 02:28 PM
04-25-2019 02:19 PM
It depends on your phone not on public mobile. What's your phone name model?
