Reply
Highlighted
Block Number
I'd rather folks didn't know my number. Is there a way to block my number from showing up when I make calls? SIMon says you can press #31#, the area code and the number to do this. However with my previous providor there was a permanent way to do it so that I didn't have to dial #31# before each and every single phone call. Wondering if PM has anything like that?
I have a Samsung Rugby III
Highlighted
Re: Block Number
Thanks.
Click the ? in lower right side of screen to start process of moderator assistance. They might be able to help you.
Highlighted
Re: Block Number
What phone model do you have? There may be a way within the phones settings to perma-block your number depending on the phone you're rocking
Highlighted
Re: Block Number
If you have an Android phone go into the dialer settings, call settings, additional settings, caller ID and out pops a menu that allows you to block your phone number.
For Iphone https://www.guidingtech.com/16889/disable-block-caller-id-iphone/
Highlighted
Re: Block Number
there is usually a way to set it in ur phone settings.. depending on what kind of phone u have
Highlighted
Re: Block Number
Samsung Rugby III flip phone.
Highlighted
Re: Block Number
@ljdemont Try this
Open phone dialer app. Go to settings.
- Advance / more options.
- Additional settings.
Look for [Caller ID]
There are 3 choices available:
- Network default
- Hide number
- Show number
Highlighted
Re: Block Number
@ljdemont
On the phone
  1. Dial *08 to turn off display of your Caller ID information on all outgoing calls.
  2. Dial *06 to turn on display of your Caller ID information on all outgoing calls.
  3. Dial *67 and then enter the phone number you want to call to turn off display of your Caller ID information for just that one call.
Highlighted
Re: Block Number
@ljdemont...In this era of spammers, scammers and robo calls...many people, like myself, won't answer  a call from unknown numbers and masked numbers. If I don't see your number...I'm not answering. I reckon alot of people have adopted the same attitude.
Highlighted
Re: Block Number
Doing it from the phone settings is a much better option because if it's turned off by the moderartors, you can't turn it  back on without their help again. I don't think the moderators will do it.
