Reply
Re: Annoying, persistent Android notification: "Sign into network"
Sing in to network xox
Hello thanks
@smallflightless wrote:
I've got a Moto G (first gen), Android 5.0.2, and a Public Mobile plan without data. Ever since upgrading to Android Lollipop, I routinely get a notification saying "Sign into network", particularly when I turn off or disconnect from wifi. If I dismiss the notification, it will just show up again later.
Obviously this doesn't have a significant effect on my phone use, but it is annoying. I've tried a couple of things, including changing the APN (Access Point Names) to the settings recommended by Public. Does anyone have any ideas about this? Thanks in advance.
Tags (1)
Try adjusting your apm settings to this:
If Android, click:
Settings > More / More Networks / Wireless & Networks > Mobile/Cellular Networks > Access Point Names >
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
If your phone won't let you adjust them, try adding a new one matching the info below exactly.
Usually you click on a + sign to add a new one.
Btw this post was originally started in 2015!
KG2
Turn off this notification
That can't be turned off.  Only way to prevent that if on plan with no data is to turn off mobile data setting.
Hai
@Cyber wrote:
@smallflightless,
Good thing to do if you do not have DATA per month.
Motorola may have introduced some bug in Lollipops.
