Reply
Highlighted
Android Codes
Here is a list with all the usefull commands about android smartphone.
To enter these codes just pull up the default dialer app and use your  fingers to press the correct buttons.
*#*#4636#*#*               Display information about Phone, Battery and Usage statistics
*#*#7780#*#*               Restting your phone to factory state-Only deletes application data and applications
*2767*3855#                It’s a complete wiping of your mobile also it reinstalls the phones firmware
*#*#34971539#*#*       Shows completes information about the camera
*#*#7594#*#*               Changing the power button behavior-Enables direct poweroff once the code enabled
*#*#273283*255*663282*#*#*        For a quick backup to all your media files
*#*#197328640#*#*    Enabling test mode for service activity
*#*#232339#*#* OR *#*#526#*#*   Wireless Lan Tests
*#*#232338#*#*          Displays Wi-Fi Mac-address
*#*#1472365#*#*        For a quick GPS test
*#*#1575#*#*              A Different type GPS test
*#*#0283#*#*             Packet Loopback test
*#*#0*#*#*                 LCD display test.
*#*#0673#*#* OR *#*#0289#*#*       Audio test
*#*#0842#*#*            Vibration and Backlight test
*#*#2663#*#*            Displays touch-screen version
*#*#2664#*#*            Touch-Screen test
*#*#0588#*#*            Proximity sensor test
*#*#3264#*#*            Ram version
*#*#232331#*#*        Bluetooth test
*#*#7262626#*#*      Field test
*#*#232337#*#         Displays bluetooth device address
*#*#8255#*#*           For Google Talk service monitoring
*#*#4986*2650468#*#*      PDA, Phone, Hardware, RF Call Date firmware info
*#*#1234#*#*            PDA and Phone firmware info
*#*#1111#*#*           FTA Software version
*#*#2222#*#*          FTA Hardware verion
*#*#44336#*#*       Displays Build time and change list number
*#06#                      Displsys IMEI number
*#*#8351#*#*         Enables voice dialing logging mode
*#*#8350#*#*        Disables voice dialing logging mode
##778 (+call)         Brings up Epst menu
The *#*#4636#*#* code is the most common one that people will use. There’s quite a bit of information you can pull up in this hidden menu.
Also this command on the "device Information" tab  it shouw your IMEI, PHONE NUMBER and your CARRIER.
If you don't know how to use this codes please don't come and say it's won't work.
WARRNING.: THIS CAN HARM YOUR PHONE PERMANENTLY.
Highlighted
Re: Android Codes
Those special codes are surely designed for the technician's ability to diagnose the problem with the phone, and that the use of those codes by regular ppl would be tantamount to warranty void
Highlighted
Re: Android Codes
Even doe are technical codes first one is very usefull when you wanna gather information like phone numbers status, etc
Highlighted
Re: Android Codes
Dude, you keep sharing information that nobody is asking for. Yeah, you have a masters degree or something (like you already shared with everyone) but stop imposing ALL your knowledge on the rest of us... it's annoying! Robot Mad
Highlighted
Re: Android Codes
Even though not an Android user, I believe more info is always better.
@daredogg You don't need to worry too much about info being widely distributed. In about 3 hours this post will disappear from Latest Topics anyway.
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
Highlighted
Re: Android Codes
No need to be so harsh @daredogg
Highlighted
Re: Android Codes
keep in mind that specific manufacturers have different codes. Also new hardware supports new codes but not the olds.
Highlighted
Re: Android Codes
No Cat Mad
Highlighted
Re: Android Codes
Here is the original thread that OP is quoting (plagarising?)
http://www.xda-developers.com/codes-hidden-android/
Either he writes for xda or ... Cat Tongue
Highlighted
Re: Android Codes
@kav2001c wrote:
No Cat Mad
Yes
Spoiler
Cat Embarassed
