Active SIM card but no data
mat_oli
I'm having a similar issue as the guy posting here:
http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/active-sim-card-but-no-service/m-p/123...
My phone is showing 4 bars of service, but I'm unable to get data. I can make/receive calls just fine, but my phone isn't showing the little "4G" or "LTE" symbol it normally does next to the reception bars. I'm using a Galaxy S7 Edge, and have the "sp.mb.com" access point configured for mobile internet, I believe that's the one that came by default with the SIM card.
Can a moderator help out here?
18 REPLIES 18
jp2
Yes, this thread is old if you need help with a similar issue I recommend starting a new thread
MeatShield
Was this problem solved?
Mary_M
Retraité / Retired
Retraité / Retired
Thank you for the update @mat_oli, it's always great reading success stories 🙂
Cheers,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
Rockdaddy22
Actually he had data toggled off.
MichelleS
You just need to set your APN settings then you'll be golden
mimmo
Happens to the best of us. Glad it's working again.
Rockdaddy22
Glad you figured it out 🙂
mat_oli
ok I'm the biggest dummy. I went back and checked the "mobile data" toggle in android settings, and it was off..thanks mimmo for your help!!
Ugh..I feel like such an idiot right now.
mat_oli
4408.769  /  12288 MB
Still got quite a bit of data left Smiley Very Happy
mimmo
Just had a thought what does self-serve say your data usage is? Could you maybe have used all your data? Not sure how that would show on a phone...
Rockdaddy22
You could also try facebook, twitter or instagram support.
mat_oli
Will give that a try, thanks mimmo.
mimmo
Private message Sharia with your phone number /.account number. That way she doesn't ask you for that info and reference this thread as well.
mat_oli
My APN settings haven't changed, they're the same as when data was working yesterday, which is exactly the same as in this thread:
http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-setup-data-and-APN-on-my-Andr...
I've tried rebooting my phone, popping the SIM card in and out, but all to no avail. I believe it's an account-level issue, which is why I requested moderator assistance initially. I'll try tagging them here.
@Shazia_K  can you assist here? I can PM you my account details if required.
Maybe try a quick google search, i think there is a site that helps figure out APN settings for providers.
Either way im sure those setting are in the forums.
mimmo
silly question is data turned on?  are you connected to wifi? If on wifi I you wont have lte showing.
are you sure  all your apn settings are correct. maybe delete them and add them again.
PS just saw your reply saying that it was working before.
mat_oli
The thing is, it was working just fine last night..I haven't changed any settings on my phone at all.
You're right, hopefully someone more technical can help out?
CaNuCk07
@mat_oli  For an issue like this thats probably something technical and not nevessarily the cause of PM, have a search through the forums, theres lots of helpful sources for people who had this resolved.
Maybe one of the oracles or community members who are technically inclined can help out cause its going to be awhile for a mod response.
