Reply
Highlighted
Access Point help
i need help setting up the access point APN and my new phone which is a LG G4.
the phone working i can make ph calls but there is no internet coming...
this what i did so far.
NAME
Public Mobile
APN
sp.mb.com
MMSC
http://aliasredirect.net/proxy/mb/mmsc
MMS proxy
74.49.0.18
MMS port
80
MCC
302
MNC
220
APN type
default,mms,supl
APN protocol
IPv4/IPv6
APN roaming protocol
IPv4
so what is it am not doing plz?
Accepted Solutions
Highlighted
Re: Access Point help
Thanks @brettster99 , @RasMorgan @ LG phones require at minimum a network reset and sometimes a factory reset is required. Try a network reset first.
Reset Network Settings LG Stylo 4
  1. Hold down the Power key for a few seconds to turn on the device.
  2. Then select Main Menu and Settings.
  3. After that tap General and Backup & Reset.
  4. Now choose Network Settings Reset and Reset Settings.
  5. Finally tap Reset Settings.
  6. Great!
Restart your phone, re-enter your WiFi if necessary, accept all updates.  Once you have done this use these APN settings:
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
Save, enable data and try to send an mms text message and to surf the net.  Welcome to PM.  Stay safe.
All Replies
Highlighted
@gblackma @Luddite @Naepalm @darlicious @mpcdesign @gpixel4 @z10user4
@AE_Collector
Any thoughts? I am not sure what the possible answer could be.
Highlighted
  6. Great!
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN type: Not set
APN protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
Highlighted
NAME
Public Mobile
APN
sp.mb.com
MMSC
MMS proxy
74.49.0.18
MMS port
80
MCC
302
MNC
220
APN type
default,mms,supl
APN protocol
IPv4/IPv6
IPv4
@RasMorgan  You are not doing anything wrong. The problem is that with that device you need to reset your network settings and restart the device. If you can access data then problem solved, otherwise you need to backup your phone and do a factory reset to get data going on that device.
