ACER Liquid Z220
msender
I have an Acer Z220 and it wasn't found when I put in the MEI # ....will I be able to use it?
Martin
Legend
Legend
Hello,
The IMEI checker has a long history of giving false positives. That is the reason that no one recommends it.
In lieu of the checker, people use willmyphonework.net combined with checking with Canada's blacklist.
Though each of the above two is not perfect, they are far superior, when combined, to the checker.
FYI.
Ali
Hey Msender
After I read Liquid Z220 user manual, page (72)
http://www.speakout7eleven.ca/asset/upload/phone-user-guide/user_manual_acer.pdf
I was able to know that there are different models of Liquid Z22, some of them are compatible and some of them are not so can you please confirm with us the exact model you have to insure if it's compatible or not.
THIS PHONE is 2G GSM
ONLY Rogers has the 2G GSM Fallback
You will need to buy another Phone which IS Compatible
makkahn28
HI. Checked, THIS PHONE WILL NOT work
NOT Compatible on PM's Network
