A samsung phone A
Stephen007
@Stephen007
To test whether your phone is compatible with our network and not marked as lost or stolen, click here
.Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Always good to check whether a phone will work with any provider, especially Public Mobile. Use more than one source to be sure.
https://www.kimovil.com/en/frequency-checker/CA
https://willmyphonework.net
Asking for compatibility with PM??
If so, and if it is a phone you can found on Samsung.ca, then it will work.
JK8
@Stephen007
Do you need any assistance?
