Reply
Highlighted
Re: 4G LTE band 2 (1900) and band 4 AWS(1700/2100)
At your house it's fine, but if you go to a shopping mall, airport, hospital, the PATH, or other major venues, you'll notice the difference.
Highlighted
If I were looking for a phone, does this sound like the most current information (May 2020) on Frequency Bands supported by Public Mobile?
3G
850 MHz, Band 5 (UMTS/ HSPA)
1900MHz, Band 2 (UMTS/ HSPA)
4G
1700/ 2100 MHz AWS, Band 4 (LTE/ LTE Advanced).
700 MHz A/B/C/E, Band 12/13/17/29 (LTE/ LTE Advanced).
Do I need to be concerned of:
2600 MHz, Band 7
2300 MHz, Band 40
Highlighted
3G
4G
2600 MHz, Band 7
2300 MHz, Band 40
Bands 2 and 5 are also used for LTE.
Highlighted
@hebegebe  Band 7 is important for LTE you should always look for a phone that has it
Highlighted
@hebegebe consider LTE bands 2, 5, 7. There's no B40 TDD in the network. The FDD version, B30, is available in some areas, but it's limited and not necessary.
Highlighted
@computergeek: I might be going against the popular opinion here, but if you're on a 3g plan, I would say that that the importance of LTE compatibility to be rather low.
Isn't is 3G speed on the LTE network?
Highlighted
@cnsultnt LTE still provides added network capacity and generally more consistent pings.
