Reply
Highlighted
4G LTE band 2 (1900) and band 4 AWS(1700/2100)
Hi:
I recently bought a Xiaomi Redmi Note 7 (Sub-model: China). It has the 3G 850MHz, 1900MHz and 4G LTE Band 5-850MHz, Band 7-2600MHz and Band 40-2300MHz. It's working with PM in the GTA and I have good network signal and data speed.
My question is - how important are band 2 (1900) and band 4 AWS(1700/2100) to have in a phone for the best Public Mobile (and other providers such as Rogers/Bell/Telus) signal/experience? I know that the Redmi Note 7 does have a global sub-model that has these two bands, so just thinking if it's worth getting a phone that has all these bands.
Any comments/thoughts?
Thanks.
Accepted Solutions
Highlighted
Re: 4G LTE band 2 (1900) and band 4 AWS(1700/2100)
For LTE, the main bands are B2 and B4 (B12 in rural areas), and they're equally deployed on macro sites. If your phone is missing both, you're really sacrificing your LTE experience.
All Replies
Highlighted
From my own experience, band 4 LTE is very important.  I am most often connected to that LTE band.
Highlighted
How do you determine which band is your phone connected to? Is there any mobile app that can be installed on a phone to check which band is the phone connected to? Thanks.
Highlighted
Try network cell info lite.
Highlighted
I'm a fan of LTE Discovery.  You can even drop a widget on your home screen for quick reference if you're so inclined.  For example:  Fun with LTE Discovery widget, LTE bands observed in VGA
I would agree that Band 4 is pretty important.  I'm sitting in the heart of downtown Vancouver at the moment, and connected to band 4.  See my post above for other bands I've seen in the neighbourhood.  🙂
Highlighted
Thanks @Lemony_Snicket and @srlawren. I installed both apps on my phone. Both show my phone connected to Band 5 LTE. I'm in Markham now. I'll check when I'm in Scarborough.
Highlighted
I might be going against the popular opinion here, but if you're on a 3g plan, I would say that that the importance of LTE compatibility to be rather low.
I know that LTE does give better pings for data most of the time, and it does tend to handle network congestion better, but I don't often see times when 3g is so bad that it gives slower than 3Mbps speeds. I know it does happen, but just that LTE compatibility isn't as important compared to if you had a full-speed LTE plan.
Highlighted
Good to have these bands to have the phone perform at full capacity.
Highlighted
Highlighted
So I checked my phone at home in Scarborough. It connects to band 5 and band 7.
My wife's phone on PM is also a Redmi and it's a genuine global version - has bands 2, 4, 5, 7 and 40. Interestingly, her phone also shows connected to the same bands as mine - 5 and 7, and sometimes band 2, but never band 4. Our home is within 2 kms of two big Bell/Telus towers on Port Union Road and East Avenue.
This is inline with another PM user's experience in the GTA, which he has shared here, and they're also connecting to band 5 and 7, more than band 4.
Thanks.
